Aaron H
- Jun 28, 2001
Not sure which forum this should have gone in, but I'll start here.
I'm trying to plan out my cabling for my new system. The receiver will be a H/K AVR8000 and the SACD and CD player will be a Sony 222ES. As I understand it, to use the CD players DACs, I want to connect the two pieces with analog audio cables. To use the receiver's DAC's, I think you'd use a digital (coaxial or optical) cable. Of course, I'll also have the 5.1 connections for the SACD.
So which one of these two choice do you think would be the way to go? Yes, I'll probably A/B them someday, but I'd like to start out with 1 cable since they're expensive, and then make a definite choice later on.
Thanks!
Aaron
Thanks!
Aaron
