Best wood for building sub.
Discussion in 'Archived Threads 2001-2004' started by Ken Lopata, Feb 12, 2001.
  1. Ken Lopata
    Ken Lopata Agent
    Feb 7, 1999
    42
    I see most people are using MDF to build most speakers. Would no void or zero void if thats what it is called be a better alternative. What are the pros and cons of each. Thanks.
  2. Dean Cooper
    Dean Cooper Supporting Actor
    Oct 23, 2000
    972
    3
    You are correct, the no void ply is a better material to use.
    Pros: a lot nicer to work with
    stronger resistance to flexing
    looks better, IMO
    cons: its usually a special order in and is no where near the price of MDF
    Dean
  3. AjayM
    AjayM Screenwriter
    Aug 22, 2000
    1,224
    You forgot one all to important fact, weight!! 3/4" zero void plywood is a lot lighter than 3/4" MDF. For a decent sized sub that is properly braced this could mean the difference between moving around a 70lb box and a 50lb box.
    Some people also swear that void free plywood is a much better material to build a sub with.
    Some more downsides would be that MDF is easier to finish (unless the plywood is the material you want to finish it with), makes a nice edge. MDF though needs better tools to work with (carbide bits for routers, carbide blades for your saw, etc).
    Andrew
