Best wireless remote extender - Recoton, PowerMid or Radio Shack???
Discussion in 'Archived Threads 2001-2004' started by Edil Cajigas, Dec 4, 2001.
  1. Edil Cajigas
    Edil Cajigas Extra
    Feb 16, 2001
    22
    Hi!
    Ok, thanks to the help that I get from members of this forum, I think that a wireless infrared remote extender is the best option to control my equipment.
    I found 3 products in the market
    Recoton DSC-IR100 - $30.00 on the web
    PowerMid PM5900 - $40.00 on the web
    Radio Shack model (that looks like the PowerMid)- $50.00
    Any comments on the performance and quality of this products?
    Do you know any other similar product?
    Thanks!
    Best regards
    Edil
  2. Michael Johnston
    Michael Johnston Stunt Coordinator
    Nov 23, 1999
    68
    I use the Radio Shack set and they work great for me. I believe that the PowerMids and the RS ones are actually made by the same manufacturer. The only difference would be the name. Not sure about the Recoton.
    There are other higher end options such as Niles and Xantech depending on what you are trying to do.
    Michael
  3. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
    I also use the Radio Shack remote extender.....works great!
  4. Rob Blakeslee
    Rob Blakeslee Auditioning
    Sep 30, 1998
    13
    Terk makes a great RF remote extender that will allow you to use anywhere within 100+ ft of the base unit. They just started to make these again and I'm not sure if they have updated their website. I have had one for over 5 years and love it. I believe Sound and Vision had it featured in their new products section a couple of months ago.
    good luck !
  5. Edil Cajigas
    Edil Cajigas Extra
    Feb 16, 2001
    22
    Thanks for all your responces!!!
    Ok I get more feedback on the Radio Shack unit so I get that one for $60 (price in my area AUCH!). It is working perfectly, even here where all walls are concrete. But guess what? is the same Powermid unit... identical units. The Powermid is $10 to $15 less expensive so I think you can try that one without problems. The Recoton is even cheaper $29, I think that it should work as well so if you want try it.
    Again thanks for all your support! [​IMG]
    Best Regards
    Edil
