Dustin Wind
- Aug 19, 2003
I have 3 spots in my room i can put my sub.
I know your suppose to put the sub where you would be sitting then walk to those 3 spots and wherever it sounds best...put it there.
Well i don't know what to use. I only use my set up for MOVIES, but any movies with bass....i can't really notice a diffrence in the 3 spots.
I have a pretty bad ear for these sort of things.
I own over 300 DvD's....so any DvD spots anyone can think of?
Sure i tried with Attack of the clones...with the mines...but the bass is so short its hard to compare.
I need a good solid stretch of bass to compare....i've had no luck finding anything decent to test with.
I have the new Video essentials...but i can hardly hear the bass with the "Bass management" section. Just a low humming.
My SPL says its at 81 DB but it doesn't seem very loud or "boomey".
I have a Verodyne 10".
Also....should i switch the back to "phase" and "180" back and forth as i do tests?
Thanks for ANY tips or suggestions guys.
