:D
Dec 31, 2001 #2 of 5 Alf S BANNED Senior HTF Member Joined Apr 23, 2000 Messages 3,475 Real Name Alfer What receiver is it you're using?? I just go by ear but I do consult the owners manual if they offer tips. For the most part it depends on room size/shape, and acoustics within the room to determine what delay is needed (if any). Alfer
Dec 31, 2001 #3 of 5 Jim_Stu Stunt Coordinator Joined Dec 27, 2001 Messages 134 Most manuals say its about 1 millisecond per foot. Think of a circle around your primary listening position, that intersects your main speakers. Then add the required delay to 'push' the center back to the circle. The rears are more subjective. If they fall inside the circle, add delay. If they are far outside the circle, you may need to add delay to the mains and draw another circle. JRS
Dec 31, 2001 #5 of 5 Jim_Stu Stunt Coordinator Joined Dec 27, 2001 Messages 134 Aaron, For most systems: Mains and rears - place on a circle around the listening position. Then use delays to 'push' the center back to the circle. For Yamaha - If the rears are outside the circle, move the mains. Remember the radius of the cicle is determined by the main placement. You cannot correct for speakers that fall outside the circle. You can correct for speakers that are inside the circle. Sub - Start with a corner placement. JRS
