Best way to hook up this system???
Discussion in 'AV Receivers' started by James Slade, Nov 8, 2003.
  1. James Slade
    James Slade Second Unit
    Nov 20, 2001
    250
    I am putting together a system with Totem mains a 2 channel Bryston amp, probably a cheap adcom preamp/tuner and I also have a Tempest sub. I haven't bought an amp for the sub yet.
    What is the best way to hook this up? I confess to only ever having used Denon receivers, so of course they had a sub out?
    Maybe I should get a cheap receiver instead to use as a preamp?
  2. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    James,
    With the equipment you've got, the only way to connect the sub is with a set of passive crossover networks. Unfortunately, high-quality, low-loss networks at, say, 80 Hz are going require some huge and expensive inductors and capacitors. I don't recommend it. Better off buying a plate amp for the sub. That way, you'll get the crossover and the amp, as well as a boost network and phase controls if you need them.
  3. gregD
    gregD Second Unit
    Jan 16, 2003
    420
  4. James Slade
    Nov 20, 2001
    250
    That Anthem looks sweet, but I was hoping to go used on the preamp.
    As far as running the audio to the plate amp for the crossover, I tend to wonder about the adverse affect this could have on the signal, but of course I have no experience here. It doesn't seem to me to be common to hear people put a plate amp in between a nice preamp and something like a Bryston or Parasound. Is anyone doing this with good results?
  5. Dave Milne
    Jul 2, 2001
    568
  6. James Slade
    Nov 20, 2001
    250
    Dave,
    I don't understand option 1. How does the sub get a signal in this setup?
  7. Dave Milne
    Jul 2, 2001
    568
    Sorry, James
    I assumed a plate amp for the subwoofer in that scenario, with some y-connectors to tap into the line-level signal between the preamp and main power amp. Nothing "extra" in the mains signal path, though.
  8. James Slade
    Nov 20, 2001
    250
    Ah that makes more sense. Would this not limit the overall gain avaiable to both the stereo and plate amps?
    Thanks for your help. I really want to put this system togeher well.
  9. Dave Milne
    Jul 2, 2001
    568
  10. James Slade
    Nov 20, 2001
    250
    Well I guess I could give that a try. The Totem Sttafs are rated down to about 39Hz. So I guess I could run them full range and just cross the sub low. It is worth a try. Going with a plate amp for the sub isn't so bad. I'll be keeping this sub forever. If/when I build another, I'll just have to get an amp to run it.
    I would love a high-end preamp, but it isn't in the cards. I am hoping to get a decent used preamp from here or some other place to buy used gear.
    I guess trying to do this sort of cheap, I have to compromise somewhere. Honestly, I suspect I won't use the sub that often anyway.
  11. James Slade
    Nov 20, 2001
    250
    Another question.
    Balanced connections, I guess these kill hooking up a sub?
    Also output voltage of preamps, is this a concern? The numbers seem to vary a fair bit. Does anyone look at this spec, should I?
  12. James Slade
    Nov 20, 2001
    250
    TTT
