Best way to connect???
Discussion in 'Home Theater Projects' started by Dave St Louis, Aug 20, 2003.
  1. Dave St Louis
    Jul 10, 2003
    20
    My H/K AVR 525 showed up today, so now trying to figure out best way to hook it up.
    Audio: from SAT, DVD, CD, they all have dig. optical out,dig. coax out, should I use them, or stay with the analog? I guess If I want Dolby, I HAVE to use the dig. output,at least on the DVD and SAT, right? Will it matter on the CD? I have decent analog(?) cables now.
    Video: Whats the best output(to the 525)to use? I have S-vid or regular RCA type connectors, and even component out on the SAT rec. I'm using a good Monster S vid cable between the 525 and the TV, and using the 525 to switch.
    Can I use a decent analog RCA style cable I have here for vid out from a VCR I still use a little?
    And lastly, whats the best way to hook up to the sub using the preout from the 525. RCA style cable again?
    Sorry for all the questions, I'm a noobe to all this.
    H/K 525, NHT SB3s, NHT SC2, NHT SW10, Panasonic GAOO
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,111
    36
    6,610
    Katy, TX
    Wayne
    Hi Dave,
    A belated welcome to the Forum!
  3. Dave St Louis
    Jul 10, 2003
    20
    Thanks! The sub cable has to be a 75ohm cable??
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Not necessarily but often it is. It's the shielding that you're after and that's generally a coax.
