Best way to connect PC to Receiver (wirelessly) for MP3's?
Discussion in 'Archived Threads 2001-2004' started by RajeeK, Jun 27, 2002.
  1. RajeeK
    RajeeK Second Unit
    Apr 17, 1999
    394
    Well we are in the middle of a move right now and our PC is just too far away from the reciever to run audio cables in our new place. I have heard of a wireless connection for audio from the PC to Receiver, but don't know where to start looking for products or what is available. Any suggestions out there so I can continue to enjoy MP3's on my primary stereo? Thanks.
  2. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    110
    Go to www.turtlebeach.com and check out the AudioTron mp3 player. Get a Linksys WET11 to work with it, and you'll be all set. Total cost, about $400.
  3. RajeeK
    RajeeK Second Unit
    Apr 17, 1999
    394
    Don,
    Thanks for the suggestion, but a bit more than I want to spend. Any other cheaper suggestions out there?
  4. DonRoeber
    Feb 11, 2001
    1,849
    110
    I'm not sure then if it's still available, but look for the Diamond Rio Receiver. It's about $150, and not as good as the AudioTron, so look for some reviews. You'll still need the $100 Linksys WET11, as it's a wireless to wired ethernet bridge.
  5. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    The cheapest solution for this you'll find (as far as I know) is the Jensen Matrix. It's a simple transmitter/reciever that plugs into the output from your soundcard and into the inputs on your A/V reciever. Very simple and not too expensive.
    You'll want to find some reviews of it....the few I've been able to find say that it doesn't give you the best sound. I belive it works on 900mhz technology, so....draw your own conclusions. It's supposed to have a 150' range.
    You can get some basic info at....
    https://www.recotondirect.com/LoginD...age.asp?id=484
    But I'd do a search at www.shopping.yahoo.com or other shopping sites to find the best price. Seems like I've seen it for about $50 or $60.
