Best way to clean audio albums?
Discussion in 'After Hours Lounge (Off Topic)' started by SteveSpoon, Feb 26, 2004.
  1. SteveSpoon
    SteveSpoon Stunt Coordinator
    Feb 12, 2002
    231
    I may be the last guy alive who still listens to vinyl, but I was wondering what the best way to clean up an old album? Your input appreciated.
    Steve
  2. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
  3. Josh Simpson
    Josh Simpson Supporting Actor
    Jan 23, 2002
    926
    You are far from the last guy to listen to vinyl, and I agree, that link should tell you everything you need.
  4. Rob Gardiner
    Rob Gardiner Cinematographer
    Feb 15, 2002
    2,950
    BACK TO MONO!
    You are not alone. Hearing The Beatles on vinyl for the first time was a revelation; I immediately sold my CDs.
    To answer your question, the DISCWASHER unit has always worked well for me.
  5. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    The best way? This:
    Nitty Gritty
    or
    VPI Industries
    I strongly suggest one of these types of cleaning machines for those who buy used albums. It is an expensive investment (it's hard to find a good deal on these machines), but well worth it.
    The Discwasher brush (I do use one) is for a basic cleaning prior to a listening session. Used records need more scrubbing than that provided by the Discwasher system. A proper wet/vaccum system will get the grime from deep in the grooves. The big reason is, with a cleaning machine, you let the solution soak for a while, releasing the dried on stuff more effectively. If you think vinyl sound good now, try an album after a proper cleaning on one of these machines. Like I said, well worth the investment.
    P.S. I think Audioadvisor.com has a basic manual vaccuum cleaning machine for $199.99.
