Best way to apply cleaning solution to screen?
Discussion in 'Displays' started by Chris_Matthews, Apr 11, 2004.
  1. Chris_Matthews
    Chris_Matthews Auditioning
    Apr 9, 2004
    12
    I just bought some of this Screen Kleen stuff for my rp hdtv. It says it's ok to just spray it right on. Would it be best to spray it on the microfiber cloth first? I don't know if I'd be comfortable spraying it directly onto the screen.
  2. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    Spray the microfiber. If you spray too much on the screen, some of it will dribble down below the screen frame. Once it reaches the bottom edge of the front screen plastic, it will wick up and in between the fresnel and lenticular plastic layers. You'll end up with an ugly, half-moon discoloration of the screen due to the trapped liquid. The only fix for that is total disassembly of the screen and careful cleaning of the two plastic layers. You don't want to do that if you don't absolutely have to.
