Best WAV to MP3 converter
Discussion in 'Archived Threads 2001-2004' started by Mike LS, Jul 25, 2002.
  1. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    I need a program to convert WAV files to MP3. I've recently reformatted my machine and I didn't think to write down which utility I was using at the time. Something like DB Poweramp or something.
    It worked OK, but I found that if I gave or emailed someone an MP3 that I created with the program, the recipient's computer could not figure out what program to open the file with. They always had to manually associate their MP3 player with the file. So I wasn't too happy with that part of it.
    Just a note, I don't need to go from CD to MP3, I need to convert from custom WAV files to MP3, so an audio grabber program like EAC isn't what I'm needing (unless it does this as well).
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    I've always found CDEX to be the best all around frontend tool.
    -Vince
  3. Jedd
    Jedd Second Unit
    Feb 5, 2002
    298
  4. Steven K
    Steven K Supporting Actor
    Jan 10, 2000
    830
    Definitely use LAME...
    it's open source too!
  5. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
  6. Mike LS
    Jun 29, 2000
    838
    OK, I checked out the r3mix site and wound up downloading the WinLame program.
    Seems good so far. Thanks for the suggestions.
  7. Joe Hsu
    Joe Hsu Supporting Actor
    Jul 2, 2001
    812
    I was going to suggest r3mix as well, and I would suggest using EAC as your client (if you're ripping CDs) and then LAME as the encoder. Check out the alt preset standard...
    Here's a helpful guide.
    g'luck [​IMG]
  8. JeffTodd
    JeffTodd Stunt Coordinator
    Jan 28, 2002
    200
    What would be yall's recommendation if I want to go from MP3 to wav? I know, kinda off, but I want to jack with the sound file itself.
    Thanks.
  9. Joe Hsu
    Jul 2, 2001
    812
    Jeff, if you go to the link I posted in my last post, and just go to the main website, he discusses decoding, and suggests using a plug-in called MAD, and gives links that explain why it's so good.
    Enjoy. [​IMG]
  10. Jedd
    Jedd Second Unit
    Feb 5, 2002
    298
  11. Kimmo Jaskari
    Feb 27, 2000
    1,528
    MP3 Decoder is also rather nice.
    Winamp does a good job too if you don't want to bother with installing a separate application.
  12. Patrick_L
    Patrick_L Second Unit
    Oct 18, 1999
    271
    don't use lame if you intend to play mp3 encoded cd's on a Panny RP56. player tends to skip/stutter on lame-encoded mp3's.
  13. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Patrick - I've given Lame-encoded MP3 CDs to people with the Panny RP91 (not sure how similar it is to the 56) and found that they had to be in Joint Stereo to work properly.
