Best version of X-Men? (1 Viewer)
ChristopherM
I know that some Region 1 THX DVDs are inferior to non-THX R2 versions (eg the original releases of the Die Hard movies).
On the other hand, I also know that some R2 PAL transfers are inferior to the corresponding R1 NTSC transfers (eg at least one of the R1 Star Trek DVDs had a better picture than the UK version, and the R1 version of Gladiator had better sound than the UK version).
So, does anybody know for sure whether the R1 THX version of "X-Men" is better or worse than the non-THX UK R2 version, in terms of picture and/or sound?
Many thanks.
Jerome_m
All I can say is that the German DVD of X-men is a very good transfer. I suppose that the UK DVD uses the same transfer.
Since it is distributed worldwide by FOX, I also suppose that all DVDs (PAL and NTSC) come from the same HDTV transfer, but I was not able to check.
CoolMovies
