Best TV Tuner PCI card for XP?
Discussion in 'Computers' started by Stephen Orr, Nov 30, 2003.
  1. Stephen Orr
    Stephen Orr Screenwriter
    Mar 14, 1999
    1,099
    I'm interested in hooking a cable connection into my PC. I just got 2 200GB HDs at CompUSA, and want to use them to do some offline recording, and possibly transfer some shows to DVD-RW to watch downstairs. Any suggestions?
  2. JohnPop
    JohnPop Stunt Coordinator
    Nov 26, 2003
    54
  3. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
  4. Joe Ku
    Joe Ku Stunt Coordinator
    Apr 1, 2003
    69
    Video capture can be very hit and miss depending on your capture card, system configuration and software choice. The two links I am giving you should lead you to all the info you will ever need to produce perfect video capture everytime.
    www.vcdhelp.com and www.doom9.org
    check out the reviews under "capture cards" you will see that many cards do not produce the advertised results. If you are looking for a cheap card though check out this deal
    At officemax.com
    Avermedia DVD EZMaker PCI
    FREE after rebates - deal expires 12/6/03
    http://www.officemax.com/max/solutio...3&moreInfo=yes
    It gets decent reviews too.
  5. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Flyvideo 3000 if you plan to use the tuner. $60 at Tecnobazar.com. The most compatible, the best video, plus it gives great S-video capture. I went through 5 TV tuner/capture cards before finally being satisfied with a Flyvideo.
  6. Stephen Orr
    Mar 14, 1999
    1,099
    How about the PCTV from Pinnacle? Is anyone using one of these products? I see that a lot of PC TV tuners that record TV programs are in mono.
