Best sub for hybrids
Discussion in 'Speakers' started by Doug Fogle, Jul 28, 2003.
  1. Doug Fogle
    Doug Fogle Stunt Coordinator
    Aug 15, 2002
    94
    Okay.both svs and Hsu seem to make great subs and I'm not trying to cause a "mine is better" flame war.But does either of these have an advantage when linked with ribbons?i.e. is one "faster" and thus better able to mesh?Hsu mentions on their website they match well with ribbons,which is why I ask.because I'm leaning towards the 25=pc 31+ right now.
  2. CurtisSC
    CurtisSC Screenwriter
    Jan 28, 2003
    1,412
    I have read the same.
    I think this is going to end up being a "try it out for yourself" deal. I understand that ribbons are tough to deal with all the way around.
  3. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    Doug, SVS and Hsu subs will sound great (especially the larger ones) but for the best sound quality to match with ribbons, you could consider a sealed or dipole subwoofer. Are your speakers dipoles? What kind are they? And how much output do you want?
  4. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    The thread title says these are "hybrids", is there a sealed, monopole woofer built in? If so, then you're not not mating a sub to ribbons but, rather, to another dynamic woofer. In either case, none of the SVS or Hsu models is anything like the mass-market dreck often palmed off as "subwoofers", and any should be "fast" enough (bass is slower than the rest, of course). You might also find a nice sealed sub suitable depending on system use and volume needs. The best I've heard of these you can make yourself for less than any of the options above.
  5. Doug Fogle
    Aug 15, 2002
    94
    They have two 6'' aluminium woofers and ribbon tweeter and are not dipole.
  6. Michael R Price
    Jul 22, 2001
    1,591
    Ah, nevermind, that is not a problem more than any regular speaker. Any good vented or sealed subwoofer will be quite satisfying.
    I do recall people with big Magnepans or other full range dipoles saying the bass quality isn't improved enough with a typical subwoofer, though.
  7. Jack Gilvey
    Mar 13, 1999
    4,948
  8. Michael R Price
    Jul 22, 2001
    1,591
    I'm thinking about making one of those H-frames with a couple cheapo PE woofers, myself. But I don't have dipole speakers. The funny thing is if I had a dipole sub, it wouldn't extend as deep as my main speakers without EQ. [​IMG]
  9. Jack Gilvey
    Mar 13, 1999
    4,948
  10. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    Just as Jack mentions, when a dipole sub is properly built and set up it can give you incredibly nice sounding bass at the expense of a fairly large "enclosure" and higher driver expense.
  11. Curt C
    Curt C Agent
    Oct 3, 2002
    27
    For years I've had great luck using sealed box subs with ribbons, Maggies and other dipole speakers. Currently I'm using a Velodyne HGS-15 crossed over at 50hz to Maggie 1.6's. This is in a large open area and sounds fantastic. I also tried the 1.6's in a small room with the Velodyne SPL-1200, same great sound. It's hard to beat a sealed box for clean accurate bass and servo (done right) sure keeps distortion down. You might want to try several designs and see what you think.
    Curt
  12. Michael R Price
    Jul 22, 2001
    1,591
    Jack, that is why by "cheapo PE woofers" I meant 2 of the Quatro 15's or four PA woofers (someone made a pair of push-pull dipoles with them... 0.67 Qts, 6mm Xmax, and 26Hz Fs for $40) and I would not choose a baffle with less than 24" in front-to-back distance. Additionally, I've read some articles suggesting the effective "Fequal" cutoff of a dipole may be at a lower frequency than predicted by Linkwitz and others. That would explain the deep results claimed by many dipole users, although I do not understand the physics causing these effects. My math suggests one of those systems would be good for a respectable 100db at 30Hz. The application is music only - no TV yet!
  13. Jack Gilvey
    Mar 13, 1999
    4,948
