Nothing fancy, just something sturdy that will suit what I need. I have two Klipsch satellites. I would perfer not to order online unless the shipping is cheap.
Which speaker model? I had my RB-25's on cheap MDF Sanus BF31's, and they resonated and wobbled, resulting in a loss of bass response and a zingy, uneven treble. Changed to steel VTI stands that were sand-fillable (which I did), and it helped tremendously. Get something sturdy and stable. Check here:
For those size speakers, any of the small stands that you would find at your local Best Buy or Circuit City should be sufficient. I think the manufacturer is Omnimount.
What model of "satellites" do you have ? The quintets? If so I bought the cheap model at partsexpress for like $30-$40 bucks. I have pictures of them setup if you'd like.
