Best small sub for music?
Discussion in 'Archived Threads 2001-2004' started by RobCar, Nov 30, 2002.
  1. RobCar
    RobCar Stunt Coordinator
    Nov 27, 2002
    201
    Hi, so I've decided to get a sub instead of upgrading my mains. I'm in a small living room and have been wanting to add more depth/bass to my music. Listen to music mostly, watch movies sometimes. What does everyone recommend for a small, tight sub for music? I just want it to fill out the lower end subtly, not shake the house down. [​IMG]
  2. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    I think it might be easier for people to give recommendations if you state what kind of budget you're dealing with and maybe the associated equipment. Also how small is small to you? Do you mean something not SVS size or Sunfire Jr type?
  3. Frank Carter
    Mar 12, 2002
    1,187
  4. Craig Morris
    Craig Morris Stunt Coordinator
    Oct 10, 1998
    195
    In the cheap range, Energy/Mirage 8".
    In the expensive range, REL Strata III (or maybe the new Quake).
  5. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    http://www.adireaudio.com/home_audio...eries/rava.htm
    RavaSE. If you are only really doing 2ch stuff you'll really appreciate the 4th order crossover built into this thing. 18" cube, excellent 12" driver, low Q sealed design. Makes for an excellent sub to fill in the bottom end of a 2ch system.
  6. RobCar
    Nov 27, 2002
    201
    I was thinking $300 or less ... is that reasonable?
  7. Frank Carter
    Mar 12, 2002
    1,187
    Not unreasonable, my choice would be the Infinity IL100s. Available from ebay seller: harmanaudio or at ubid.com(authorized dealer) for under $300 shipped. Also available in black, cherry, or maple. Solid response down to 25Hz and on board single band parametric eq. I used to have it and it was one of the most musical subs I've heard at any price. Not too big as well.
  8. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Can you DIY?
  9. RobCar
    Nov 27, 2002
    201
    DIY? I dunno. No experience, but not opposed to the idea.
    looking into the Infinity IL100.
  10. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Titanic 10" kit. I had it once and loved it for music. Tight and fast, hit hard with Rush, Floyd, etc, yet was also there for "ambient" bass in large room recordings of classical.
    $349 at partsexpress.com, also on ebay from them. That's where I got mine, $314 shipped. 1 hour and it was up and running.
    It's NOT as good looking as the Infinity, though, and if the Infinity sounded 75% as good, I'd buy it instead, but it's ported and the driver is not likely to be as well built as the Titanic.
    My $0.02...
    Good Luck!
  11. Craig Amrine
    Craig Amrine Auditioning
    Aug 20, 2002
    9
    Try the 8 inch subwoofer at aperionaudio.com
    It has been great for me.
    -craig
  12. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    If you have some basic woodworking skills and tools (or access to), do some reading in the DIY/Advanced section. You can build a very nice sub for around $300. Significantly better than anything commercially available in that price bracket.
