Steven Larson
- Mar 9, 2004
Ok, I got quite a bit of good advice about tv's earlier, and I know that the general consensus is "bigger is better". I was initially looking at 46" rptv's, then started thinking 51 or 53 (like the Panasonic), or even 57.
My living room is setup with a fireplace at one end, so I will have the tv on one of the long sides, with the couch on the opposite side. This means my couch will be about 10 feet from the screen. I ran the Viewing Distance Calculator, but I am having a hard time interpreting the results. To my mind a 53" or larger tv could be pretty big in this room, but the calculator seems to indicate that an even bigger tv would do.
Is 10 feet going to be okay with a tv somewhere between 46 and 53" diagonal screen? Will I have a good picture at that distance?
Steve
Steve
