Best Receiver for DVDs at $500 (or less)
Discussion in 'AV Receivers' started by Dave H, Jan 20, 2005.
  1. Dave H
    Dave H Producer
    Aug 13, 2000
    5,580
    208
    9,110
    Currently, I have a Yamaha HTR-5240 receiver. I've had it for over four years. I've been happy with it, but I want to move up to a higher sound quality ---the use is strictly for movies - DVDs, etc.
    I was looking at the Yamaha HTR-5790 or 5760.
    Anything else that I should look at? Again, I'm looking for a nice jump from where I am at right now with audio quality. I'm not concerned about gimmicks and functions, etc. --- just pure sound quality.
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Good luck with Yammy? I say stick with them!! [​IMG]
  3. Dave H
    Dave H Producer
    Aug 13, 2000
    5,580
    208
    9,110
    I have definitely been happy with my current one. I just want to move the the next step -- preferably with a Yammy. Am I likely to get better sound with the models I mentioned?
  4. James Phung
    James Phung Second Unit
    Jun 4, 2004
    409
    The 5790 should help give better sound as the YPAO does auto EQ set up. You should also consider the Pioneer 1014, which is what I'm using.
