Best Projector+Screen possible for $3000
Discussion in 'Displays' started by Aaron_*P, Dec 19, 2003.
  1. Aaron_*P
    Aaron_*P Stunt Coordinator
    Nov 22, 2003
    50
    What's the best projector and screen combination possible for a total budget of $3000? I've been looking at mostly dlp, the rainbow affect doesn't bother me and they seem best bang for buck and quality. Any opinions are greatly appreciated. Hoping for about a 100 inch screen (or bigger, but can go a little smaller too if needed). The dimensions and distance between projector and screen can be just about anything (within reason) because I can arrange the room anyway I want and have multiple rooms in my house I can put it in. There will be some, but minimal ambient light.
    Might be able to put the budget up to $3500 tops.
    Aaron.
  2. TommyL
    TommyL Supporting Actor
    May 27, 2002
    590
    DLP will be tough in that range...look at the new Sanyo Z2(lcd) and a carada screen...many happy campers with this combo...pm me and I can give ya any details. tom
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    8in EM focus CRT, driven by an HTPC.
    Hands down.
    [​IMG]
    But then again, I'm biased...
  4. Darrel McBane
    Darrel McBane Second Unit
    Oct 8, 1999
    363
    I'm going with the Sony HS20 LCD projector. I contacted Oades Brothers and they quoted me $2795 shipped. I found a local dealer who will sell me one for $2700 out the door. Going local and picking up a pulldown screen (1.78 HDTV format 45"H X 80"W). I'm looking at a Draper screen right now. I'm waiting for a quote for their screen. I'm hoping to get the screen under $400. You may want to look at contacting Oades and consider this route also.
  5. Dennis Nicholls
    Dennis Nicholls Lead Actor
    Oct 5, 1998
    8,936
    347
    Boise, ID
    Dennis
    For $3500 I got a used Electrohome Marquee 8501LC and a 100" 4:3 Vutec screen. This is one hell of a combination. However I did buy the projector used.
  6. Adam Gutierrez
    Adam Gutierrez Auditioning
    Jan 11, 1999
    12
    Aaron,
    For $3500 and DLP I would buy an NEC HT1000 and do an inexpensive(
  7. ChrisWiggles
    Aug 19, 2002
    4,791
    Adam: perhaps the best among digital projectors, but if he's also considering the used CRT route, then it's not a fair comparison.
  8. Torgny Nilsson
    Torgny Nilsson Second Unit
    Jan 8, 2003
    255
    Do FP LCDs have the same pixel burn out problem that RP LCDs have? It would suck to have a couple of pixels burn out when they are being expanded to a 100 inch screen.
  9. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    LCD's whether FP or RP will have dead pixel/subpixel issues. It's luck of the draw.
