Best projector for a small screen
Discussion in 'Displays' started by Chris*Lev, Aug 16, 2005.
  1. Chris*Lev
    Chris*Lev Auditioning
    Aug 16, 2005
    3
    I'm in a room that runs 11 x 12 with a 9 foot ceiling, it has a small amount of light which comes in through the cracks in blinds. Inside, I have superb sound, and am now interested in having a projector to go along with it. All I want to cast is a 36" x 48" image to a da-lite da-snap mat. Keeping in mind that I would be watching TV & DVD's what would be the best bet in way of projector for the lowest possible price(400-900)? Also, do you think that I should just skip the projector and go for a flat screen or LCD instead?
    Any advice would be greatly appreciated as I would like to get my "mini home theatre" up and running as soon as possible. [​IMG]
  2. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Chris, why do you want such a small screen? Any projector will look great with such a small screen, but it seems pretty silly to me. Do you want LCD or DLP?
  3. Chris*Lev
    Aug 16, 2005
    3
    I was looking for the most cost effective choice... so i was thinking small screen = high brightness = small cash
    Really I meant that size screen would SUFFICE thought a larger picture would be better. I would be using this as a permanent setup within the room so I guess I'd be looking for a DLP (but I really have no clue considering how new I am to all this) once again any help would be GREATLY appreciated
  4. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Chris, I would try to find an Infocus X1. Check Google.com, they're still out there, new and refurbished. I have it and it's great. You can get a 68"-81" diagonal widescreen picture with a 11' throw distance with the X1. It also would be great for watching TV, since it has the Faroudja de-interlacer inside.
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Please gentlemen: Read the red-lettered posting atop the thread-listing page in Basics, particularly the last sentence. Ask for specific shopping advice in the appropriate hardware-related area; the Basics section is for general discussion at the beginner level only. Thank you.
  6. Luis Gabriel Gerena
    Luis Gabriel Gerena Second Unit
    Jul 18, 2000
    410
    Ive seen the Infocus 4805 for $800-900. You wont find a better deal than that. I am projecting a 9' wide screen and thats using low power mode and still is bright enough to delive theater like image. I am using a simple and effective $30 Blackout cloth. Have you seen my screenshot's thread in this forum?
    regards
  7. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    You are looking for a 4x3 projector (36" x 48") as per your question. The Infocus 4805 is a native 16x9 projector whereas the Infocus X1 is native 4x3. If you can still find one that may be a good choice for this scenario.
  8. Luis Gabriel Gerena
    Jul 18, 2000
    410
    I recommended the 4805 cause he mentions he wants to watch DVDs also.
