Best Progressive Scan DVD under $350?
Discussion in 'Archived Threads 2001-2004' started by Dirk Grace, Sep 6, 2002.
  1. Dirk Grace
    Dirk Grace Agent
    Aug 24, 2002
    25
    OK Folks. Lets see what the best progressive scan DVD is for under $350. I want to watch Blade Runner on my big screen and feel as if I am there.
  2. Manny_S
    Manny_S Stunt Coordinator
    Sep 4, 2002
    54
    How about the Panasonic RP82 which uses the excellent Sage/Faroudja chip. I paid $192 for mine.
  3. Dirk Grace
    Dirk Grace Agent
    Aug 24, 2002
    25
    Thanks for the input Manny. This one looks promising.
  4. Gregg_Fritz
    Gregg_Fritz Extra
    Sep 3, 2002
    20
    Samsung's new progressive scan ROCKS.
  5. Dirk Grace
    Dirk Grace Agent
    Aug 24, 2002
    25
    What about the "Nintaus PDVD-9769"? Anyone using this DVD player?
  6. Dirk Grace
    Dirk Grace Agent
    Aug 24, 2002
    25
  7. Adam Bluhm
    Adam Bluhm Supporting Actor
    Feb 9, 2002
    611
    It sure does, Dirk. The 'S' stands for silver.. I think.
  8. Mike Newmarket
    Mike Newmarket Auditioning
    Aug 27, 2002
    7
    When hooked up to my Sony direct widescreen (K34XBR800), my JVC DVD player (xv-d721bk) looks better using the 525i component outputs than with the 525p component outputs.
    Do I need to do some serious tuning?
  9. MitchellC
    MitchellC Extra
    Apr 28, 2002
    15
    Mike, it may mean your TV's internal line doubler is better than the one that the DVD player uses.
  10. Mike Newmarket
    Aug 27, 2002
    7
    Thanks Mithchell - I think (and hope) that your're right on
  11. ChrisMatson
    ChrisMatson Cinematographer
    Dec 14, 2000
    2,181
    110
    I have been very pleased with my Toshiba SD-4700.
    The new 4800 or 5800 may be even better?
  12. Dirk Grace
    Dirk Grace Agent
    Aug 24, 2002
    25
  13. Manny_S
    Sep 4, 2002
    54
    Dirk, the picture of the RP82S on Panasonic's website is incorrect. That's a photo of the prototype. Crutchfield, the link I provided on the first post, has the correct photos of the unit. The RP82 is not available in black, unfortunately. If you can get used to the Chrome/Silver color, then I'd go with the RP82. If you don't care about MP3 playback capability, then you can go with the RP62. It's the same player but without the MP3 playability, and most importantly, at a lower price.
  14. Dirk Grace
    Dirk Grace Agent
    Aug 24, 2002
    25
    Thanks Manny. I will likely go with the Panasonic, but would like to get some more information on the Philips.
    Dirk
