Chris-C
- Dec 7, 1998
Hi Gang;
Here's the deal.....As we know printer ink cartridges are muey expensive. The problem with cheap cart's is that they don't work as good as the expensive cart's.....sooo is there a good printer that works well with cheap online cartridge's????
I'm using an Epson C84,an I can't get rid of the crappy lines unless I run the head cleaning process....which causes the ink supplies to drain very quickly (possibly intended to do so by printer maker's).
Sorry for the low budget approach,but can't afford the pricey ink cartridges.
Regards
CC Rider
Regards
CC Rider
