Best Player for $250-$300
Discussion in 'Playback Devices' started by Tim Jin, Jan 19, 2004.
  1. Tim Jin
    Tim Jin Supporting Actor
    Jan 12, 2003
    529
    Hi,
    I need to get an new DVD player. My budget is $250-$300.
    Suggestions would be very helpful.
  2. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    Get a top-rated model with the Faroujda de-interlacer. Used models: Panasonic RP82,XP30,XP50 or Denon DVD-1600. New models: Mitsubishi DD-8040 or Denon DVD-910.
  3. Tim Jin
    Jan 12, 2003
    529
    Do you know how does the Toshiba SD4700 stacks up to?
    I really would like to stay away from Panasonic.
  4. Don_Berg
    May 30, 2003
    931
    The Toshiba is inferior, it has a cheap low-quality de-interlacer. You need to get a higher quality model with the Faroudja de-interlacer to rise well above the pack of the lowend models. The common players by Sony, Toshiba, and the newer Panasonic models all use inferior de-interlacers and have the chroma bug.
