Best new AV Receiver under $1,000-$1,500???
Discussion in 'Archived Threads 2001-2004' started by Paul Fa, Nov 9, 2001.
  1. Paul Fa
    Paul Fa Stunt Coordinator
    Nov 6, 2001
    74
    Question to the collective: I have a Toshiba D2705 DVD five disk changer hooked via component output/input monster cable to a JVC AV 32D501 TV and an older 'regular' Sony integrated stereo system. It's time to upgrade the receiver at least to a current surround sound system and I'd like your opinion. I was thinking about the Harman Kardon AVR 7000 which gets absolutely fantastic reviews for sound quality etc., but miserable reviews in terms of build quality (see reviews at AudioReview.com). What is your experience? I have also read about problems between certain Yamaha receivers and the Toshiba DVD players so I might be a little leery there. I want good-great sound (but not above human hearing - the dogs bark at enuf stuff already), lots of inputs and outputs and good-great reliability - who provides it for under a grand or so???
    Thanks!!!
    PS: I am not totally against separates, just would need them to fit the same buying criteria.
    [Edited last by Paul Fa on November 09, 2001 at 10:37 PM]
  2. Peter Jessee
    Peter Jessee Stunt Coordinator
    Sep 25, 2000
    149
    I'm a long-time fan of the Denon receivers, and currently use a AVR3300. The AVR3802 has tons of features, pretty good sound, and recently dropped to $1000 list. You can also get an AVR4800 for around that. It doesn't have DPLII, but it is a big step up in build and sound quality from the 3802.
    Also check out the Onkyo 898 at $1500 list but frequently discounted. Yamaha has some new models shipping soon, so they would be another possibility.
    The $1200 Rotel is down on features and power compared to the others, but has excellent stereo sound quality.
    My experience with the HK7000 matches your information - tons of power and great sound, russian-roulette quality control.
    Good Luck!
    Peter
  3. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    You should look at the Yamaha RX-V1...which you might be able to find for $1500 street price.
    I wouldn't worry about having any major problems with Yamaha...they are consistently at the top in terms of reliability and/or build quality.
  4. Bobby T
    Bobby T Supporting Actor
    Mar 13, 2001
    583
    I'll second the Denon
    Mongo like HTF
  5. John Morris
    John Morris Guest
    Alot of good choices have been mentioned but I'll throw my personal favorite into the mix, and that is the Sherwood Newcastle R-963. If you can find one(they are brand new), you probably can get this for around $1500 or so. Check it out here: http://www.sherwoodusa.com/newcastle/rec_963.htm
    God Bless America!!!
  6. YANG
    YANG Second Unit
    Feb 10, 1999
    484
    4
    110
    You may wanna take a little look at OUTLAW 1050 AV receiver...the current hot favorite among the forum members.
    I would suggest to you that to take a big look at SHERWOOD range of receivers,especially the NEWCASTLES which gives you the best bang for every bucks you spend.
    DENON products are quite impressive too,you can now enjoy DPL2 for less than US$1.2k.
    HARMAN KARDON? Just the name itself,will be very expensive to me!
