Best Inexpensive Receiver as Prepro
Discussion in 'AV Receivers' started by David James, Mar 11, 2004.
  1. David James
    David James Stunt Coordinator
    May 25, 1999
    194
    I'm looking for a receiver to use primarily as a prepro for a home theater. Wattage isn't much of an issue as I have separate amps for the front channels and will only be using the receivers amps for the surrounds. It also must have flexible bass management i.e. multiple crossovers selectable for groups of channels (front/center/surround).
    Cost is the other factor. Right now I'm thinking about HK 230 or 325 refurbs, which are selling in the low $300-$400 range. I would prefer to keep it around $300.
    I don't see a lot of other choices that meet my criteria. Does anyone have any other suggestions or thoughts on my current choices.
  2. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    Sony 2ES or 4ES, if you can find one. You could probably pick up a used one somewhere.
  3. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    If you want multiple crossovers selectable....the only ones that do it are Lexicon, Outlaw, HK, and I guess the Sony ES.
    I might try a HK 230 this weekend and compare it against my Pioneer 811.
  4. MuneebM
    MuneebM Supporting Actor
    Jan 12, 2004
    621
    Yamaha RX-V1400, no multiple crossovers but great receiver. A little over your budget so perhaps you can check out the newer RX-V740.
  5. Charles Gurganus
    Charles Gurganus Supporting Actor
    Mar 2, 1999
    689
    Why not hunt down Sony's TA-E9000es prepro? It may cost you $500 but it will SMOKE any other choice for that price and under, especially ANY receiver under that.
  6. chung_sotheby
    chung_sotheby Supporting Actor
    Apr 8, 2002
    857
    Or maybe a used HK 520 or 320. Great processing, mutliple crossovers, assignable amp channels (in case you need them) and Logic7[​IMG]
  7. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    Pioneer Elite 43TX runs about $400 or so used on audiogon. A solid 7.1 receiver, and an excellent pre/pro for that money. Has everything you could want, short of the new DPLIIx (which wasn't out when it was designed anyways).
    Worth a look. And it looks damn fine in a rack too. That high gloss black metal finish. Mmmm.
