Jose Luis
Grip
- Apr 8, 2002
Hello,friends.I'm trying to find someone with experience who helps me deciding the best choice.I have a Sony vpd mx 10 projector. How can I get the best image?
A/ HPTC with built in DVD, using dScaler image doubler program.
B/ An external DVD player connected to HTPC to be able to use dScaler,throug a SVHS connection.
C/A DVD connected to the projector, not using HTPC or dScaler.
What is the best way to interconnect?. The projector has a digital(DVI) input, a RGB input throug a 15 pin connector and a SVHS input.
Anyone has experience with dScaler? Is it really worth?
Is it not better a stright connection between DVD and projector without processing the image, as some people think?
If someone has experience I would thank very much.
