EdwinL
- Aug 21, 2002
So... what do you think the best reciever for under $500.00 is?
So wait a minute, the Denons are better than the Marantz?EVERYTHING you read here is a matter of opinion. For mostly music, the only two I would listen to are Marantz and H/K. Denon's sound cannot match these two, in this price range, IMO.
As for the Pioneer, I would only consider the Elite model. "Only" 10wpc difference may be very misleading, just as the difference between Sony's ES line and DE line is quite significant, while advertised power is nearly the same for most of their models...
Ex: 3ES rated at 100wpc, while basically every receiver above the DE685 are rated at 100wpc (sound suspicious?), which do you think actually meets it's spec? Their caveat seems to be that the ES line is "full bandwidth rated" power...
H/K, Marantz, Denon and Onkyo all have had quality issues at one point or another in the last year, yet I don't feel any of them deserve a reputation of "poor" quality.
5200 is pushing the limit of being able to deliver enough current for the M9s, IMO. It will work, but turning them up could drive them to distortion. I have a 6200 with Monitor 5s and it sounds very good.
