Best HT/Music Speakers for $1000
Discussion in 'Speakers' started by James::Mc, Aug 29, 2003.
  1. James::Mc
    James::Mc Extra
    Aug 25, 2003
    17
    Looking for the best combo home thater / music speakers I can get for $1000. Looking for front, rear, center, and sub. Was looking at the Polk RM7200's. Not sure if I'm heading the right direction...And I don't need to have all the speakers be the same - just thought that would be the right direction???
  2. george king
    george king Supporting Actor
    May 29, 1999
    625
    have brian (great guy and great craftsmanship) build you his RADMicro setup. It is 5 RAD micros and a sub all for $750. go to www.rutledgeaudiodesign.com
  3. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    I had looked at the Polk when I first actually looked at a home theatre system and a music system. The Polk for me lacked with the home theatre, it just wasn't all there, it didn't go the lower freq. that I wanted and it seemed like it just had a spot where it was empty in the mid-range to me.
    The RADMicro setup I have heard alot of good things about but I haven't tried it myself personally so I can't say but it seems like a good system.
    This would be my recommendation and you can easily go try it out at Bestbuy and see how you like it:
    Klipsch SB-1 (Bookshelf fronts, $250 a pair)
    Klipsch SS-5 (Rear Surrounds, $280 pair)
    Klipsch SC.5 (Center Channel, $180 single)
    That right there is about $710 and then you have about $290 to play around with a subwoofer. The new Klipsch RW series subwoofers are very nice but Bestbuy also carries Klipsch lower line subwoofers.
    I think that the system right there would compliment a medium sized room very nicely. I also like Klipsch because they usually are a little brighter than most speakers, some people say this helps in Home Theatre, I think that movies will sound awesome of that especially if paired up with a decent subwoofer.
    As for music the system should still be good and I think it will suit you very well.
    Of course nobody can tell you what will sound best to you because everyone has there own opinion on how a speaker sounds. That would just be my recommendation on what to buy. I hope this helps.
  4. David Preston
    David Preston Supporting Actor
    Mar 23, 2003
    698
    I bought a full 5.1 system from Brian at RAD. I went with the Micros for rears and I got the T-1 towers upfront with a C-1 center. I got a 95L Shiva sub also. It sounds awesome. If you really wanted to spend $1000 you could probably get him to do the Micros and then upgrade to another Sub to get to the $1000 mark. Like George said above the Micros system is only $750. He can finish it in many different finishes as well. I opted for the black.
  5. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    Energy Take 5.2. If the reviews don't speak for themselves, these babies rock my 14x20 bedroom. For the price, and the incredibly compact size, I don't think you'll find anything that images better than these. I'm sure a proper audition will speak for itself. I haven't heard anything that does HT and music so well.
    How big is the room you're trying to fill by the way? And what receiver will you be using?
  6. James~P
    James~P Stunt Coordinator
    Aug 8, 2003
    226
    Axioms... check thier website, they have a little wizard for it.
  7. Lin
    Lin Extra
    Jul 30, 2001
    17
    Check out AV123.com, the ELT package for $899
  8. Victor Chan
    Victor Chan Stunt Coordinator
    Dec 10, 2002
    79
    James::Mc,
    Ascend Acoustics makes some great speakers for both music and HT.
    http://ascendacoustics.com/Main/Intro/Firstpage.asp
    http://ascendacoustics.com/Main/Revi...dReprint.2.pdf
    http://ascendacoustics.com/Main/Revi...endreprint.pdf
    They have all the charateristics of a high-end audiophile speaker -- particularly accuracy and clarity -- without compromising its ability to handle HT material. I would look at the CBM-170 L/C/R with HTM-200 surround setup for $698.
    If you could get that setup with the Hsu VTF-2 subwoofer for $1148, I think you would have a great music/HT setup that I think you would have to spend considerably more in order to get noticeably better sound. But if you are capping it $1000, I would still consider the 5.0 setup and try to source a cheaper ($300) sub to complement that with the thought of potentially upgrading the sub at some point to match the quality of the other 5 speakers.
    Victor
  9. James::Mc
    James::Mc Extra
    Aug 25, 2003
    17
    The room I will be using for the next 6 months is about 20 x 20 and two stories. After that I'll move them to a 20 x 30 space with 8 ft ceilings. Ultimately looking for the best speakers for the later space.
    I am also buying a new receiver - not sure which one yet. Pioneer Elite 43 is near the top based on some responses to my receiver post...
  10. AndrewErickson
    AndrewErickson Stunt Coordinator
    Aug 13, 2003
    128
    Check out Polk at your local Circuit City, if you have one. They have most of the RTi series on clearance. I bought a CSI40 center, 2 RTi38 bookshelves, and 2 RTi28 bookshelves for surrounds for around $700.
    For a receiver, check out the Harman Kardon AVR-325 at Onecall .com for $386 refurbished.
  11. ChrisLazarko
    Aug 13, 2003
    867
    I would highly recommend either the Harman/Kardon AVR-225 for a 5.1 setup or the AVR-325 for a 7.1 setup. I have a AVR-225 with my Klipsch Quintets and from my old reciever to this it is like night and day. It sounds a world load of difference.
  12. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    Second on the Rocket ELT package. I heard this in Dallas and it was great.
  13. James::Mc
    James::Mc Extra
    Aug 25, 2003
    17
    What about the Aperion Intimus 5.1 system with 10-inch subwoofer?
  14. CurtisSC
    CurtisSC Screenwriter
    Jan 28, 2003
    1,412
  15. Tim Ranger
    Tim Ranger Stunt Coordinator
    Oct 22, 2002
    131
    That ELT system for $900 seems very nice. I haven't heard it, but the buzz is good. It also has a money back guarantee which I think is absolutely essential.
  16. Adam_Reiter
    Adam_Reiter Second Unit
    Oct 7, 2001
    461
    Without a doubt, the ELT package will BLOW AWAY "ANYTHING" in that price range. What other package for $900 can hit REFERENCE level clean as a whistle? This is Mark's crowning achievment at AV123, to get a speaker package that good for that price.
  17. JohnnyCasaba
    JohnnyCasaba Agent
    May 14, 2003
    41
    Have you heard the ELT's Adam?
  18. CurtisSC
    Jan 28, 2003
    1,412
    Adam,
    Have you been able to compare the ELT to the RS150?
  19. Mike_Gr
    Mike_Gr Stunt Coordinator
    Jan 14, 2003
    176
    I second the recommendations for Axiom and Ascend. Both represent outstanding value for the money.
    I am not sure about Ascend, but Axiom does offer a free 30 day trial.
  20. CurtisSC
    Jan 28, 2003
    1,412
    Mike,
    Ascend does have the 30 day trial period minus shipping. What do you mean when you say "free" for the Axioms? Free shipping?
