Best home theater subwoofer for $1,000 or less?
Discussion in 'Speakers & Subwoofers' started by Haris Ellahi, Feb 5, 2004.
  1. Haris Ellahi
    Haris Ellahi Second Unit
    Oct 30, 2001
    485
    Which is the best home theater subwoofer for $1,000 or less?
  2. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    DIY Tumult or dual AV15 w/ a beastly pro amp would be my choice. Commercial you're looking at maybe an SVS PB2 ISD or a 20-39 CS+ w/ a Samson 1000 amp. HSU VTF-3 may also be a consideration but i don't think it has the output of the other mentioned comercial subs.
  3. MikeLi
    MikeLi Supporting Actor
    May 6, 2003
    945
    SVS without a doubt. Call Ron there and talk to him... he will come up with the best solution for your listening area and will not over sell you.. Super company and great guys to work with.. I am on my 3rd set of subs...My last ones were dual NHT's. No compairison... the SVS beats them all hands down. I admire you DIYers... Would love to try sometime but with work and a family.. there is no time plus the cost difference is not worth the time I would spend....
  4. Luitz
    Luitz Stunt Coordinator
    Jan 4, 2004
    139
  5. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,213
    What size room are we talking about? Any openings, if so, how big are they? Do you have something readily available other than your primary receiver to power it with?
    Spending $1K just to spend it is foolishness in its finest. Better to check your needs first and go from there.
