Best home theater speakers?
Discussion in 'Speakers & Subwoofers' started by Clay McCall, Feb 10, 2004.
  1. Clay McCall
    Clay McCall Auditioning
    Feb 8, 2004
    10
    I am building a room for a home theater and I have been looking at klipsch Ref 7 Surround package with a svs-pb+ sub. Any recommendations other than the klipsch ref 7's??
  2. Justin_D
    Justin_D Stunt Coordinator
    Dec 27, 2003
    217
    Budget?
    Room size?
  3. Clay McCall
    Feb 8, 2004
    10
    Oh yea Room size is a 20x24 and a speaker budget of 4k excluding the sub.
  4. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Well, if you have listened to the Klipsch package and you really like the sound, I doubt you will find anything you like better. Klipsch has a unique sound and if that's what you like you'll probably feel that most other speakers are missing something. That being said, if you have not heard the Klipsch, or if you are not completely convinced they are for you, check out the B&W 600 (or 700) series and look at some Paradigms. Also, some online direct speaker companies seem to get good reviews around here, but I haven't heard any of the speakers personally.
    In particular, I think a pair of B&W 704's with 705's for surrounds and a HTM7 center would make a great system.
  5. MuneebM
    MuneebM Supporting Actor
    Jan 12, 2004
    621
    also check out the JBL Studio Series: discontinued, very hard to find, but awesome speakers
