best firing direction for Shiva?
Discussion in 'Archived Threads 2001-2004' started by Matt D K, Jan 27, 2003.
  1. Matt D K
    Matt D K Stunt Coordinator
    Dec 17, 2002
    51
    Will the Shiva work as well mounted vertically as it does horizontal? I would prever to mount it facing forward and the port firing down on to a base plate mounted 2-4" below. Should this be a problem? Have abou 92culiters, using PE 250w amp in a 16 x 17 room with vaulted ceilings to about 14' Used mostly for Home theater, but needs to work well with music as well.
    Thanks in advance
    Matt
  2. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    It shouldn't matter which way the SHiva is mounted, it will work fine. Vertically side-firing, down-firing, up-firing, will all work fine.
  3. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    That's a pretty big space, you might want to use a Tempest.
    Base plate should be spaced at least the diameter of the port away from the port outlet.
    All drivers work 'best' with a forward firing orientation. Over time gravity will effect any driver that is downfiring.
