Chas_Michael
- Dec 12, 2000
With all the DVD releases of the Evil Dead, Which is the best version?
Light on supplement but at least its in the original theatrical AR with the original mono English soundtrack.
The original theatrical release was not at 1.37:1, unless you're just counting the premiere (which was at an older theater that accomodated that aspect ratio).
THERE IS NO WAY THE OLD ELITE OR AB VERSIONS WOULD LOOK BETTER THAN THE NEW BOTD ON A 16:9 DISPLAY.
I'm not sure this is necessarily true. 1.85:1 transfers occupy more of the screen, but won't necessarily look better as far as picture quality. If your DVD player generates black bars on the sides of 4:3 material--JVC, Panasonic, Toshiba, Malata--then some 1.33:1 material looks great on a 16:9 TV. For example, X-Files episodes(especially seasons 3 and 4) generally look as good as anamorphic widescreen material on my 65" HDTV. Correct me if I'm wrong, but I believe you're still utilizing the full vertical resolution on full frame material, just like you would if watching them on a 4:3 set. The current versions of Evil Dead look great on my TV.
