Best DVD player value? (1 Viewer)
Craig_F
Okay,
After reading everyone's comments on my last thread, I'm leaning towards getting a single disc DVD player rather than replace my 5 disc CD changer with a 5 disc DVD changer. What model DVD player would you recommend? I'm thinking of around a $400 price point. I've always been partial to Yamaha and Denon, but my brother got a Yamaha DVD changer and has had numerous problems with it. Are there other brands that give more bang for the buck? What features are "must have"? I'm looking for quality more than quantity here. Just a basic player with quality sound and video.
AustinKW
Craig,
You don't have to worry about sound, only video. The digital connection between your player and the receiver will pull the sound "file" off the disk and shoot it over to the receiver for processing. Concentrate on video performance (no chroma bug, no flicker, scaling options, etc.) Good luck.
Austin
AlohaTiger
