Best driver for a sealed box sub (music only, no HT?)
Discussion in 'Home Theater Projects' started by Javier_Huerta, Sep 8, 2003.
  1. Javier_Huerta
    Javier_Huerta Supporting Actor
    Mar 9, 2002
    619
    So, now that my first project (Tempest AA) is well under way [​IMG], and with a new home project, I was thinking about building a sub for my personal system.
    The Tempest will be used for a pair of piston speakers - I think they'll sound pretty good, since both are ported. But the next sub *has* to be a sealed design, since my second system has a sealed woofer (or so my logic goes).
    Considering I'd like the best extension possible, and that my speakers can't play too loud, *and* that I'd love to go sealed, what options do I have? I was thinking about the 12" Titanic. Is there any other driver I should be considering?
    Thanks for your help!
    Javier.
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
  3. Javier_Huerta
    Mar 9, 2002
    619
    Jack, wouldn't a sealed sub be a better match for a sealed speaker than a vented one?
  4. Jack Gilvey
    Mar 13, 1999
    4,948
    Maybe. Why would a ported sub be a better match for ported mains?
  5. Javier_Huerta
    Mar 9, 2002
    619
    I'd love to build a vented sub for my sealed speakers, but I wonder about group delay. Especially when they are electrostatics. I'd like to have the lowest group delay possible, but an IB is out of the question. Hence - the sealed sub.
    I don't care too much about group delay on the ported speakers, since they are in my living room, and I don't think I'll use them for much critical listening...
  6. Jack Gilvey
    Mar 13, 1999
    4,948
    Makes sense to me. [​IMG] As you see from that thread, the Adire DPL12 is my favorite sealed box woofer.
  7. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Adire DPL12 is what I'd build in a 75 liter box.
  8. Javier_Huerta
    Mar 9, 2002
    619
    Great... thanks a lot, Andrew & Jack! I'll check out the DPL. [​IMG] [​IMG]
  9. dave alan
    dave alan Second Unit
    Aug 30, 2002
    256
    Re: Sealed/ported sats/sub.
    Actually, it depends on the application. If you use an A/V Pre-pro or receiver with bass management, any sub is best mated to sealed mains, when the mains are set to 'small'.
    The standard HP filter is 2nd order (12 dB/octave). When applied to a sealed (2nd order roll off) speaker, the result is a 4th order, or 24 dB/octave slope.
    The standard LP filter is 4th order (24 dB/octave), which, when applied to a sub, yields a matching 4th order slope.
    OTOH, ported mains (when set to 'small') don't match any sub because the 2nd order HP filter, when applied to a ported speaker (24 dB/octave roll off + 12 dB/octave filter = 36 dB/octave), usually leaves a hole at crossover when mated with the 24 dB/octave LP filter.
    With ported mains, it's better to set them as 'large', run a sweep and graph to determine their F3, in room, and set the sub's LP to 1/2 to 1 octave above that.
