Best DIP quad op amp for active crossovers?
Discussion in 'Archived Threads 2001-2004' started by Phil Olson, Mar 1, 2003.
  1. Phil Olson
    Phil Olson Stunt Coordinator
    Jun 30, 1997
    52
    Hi all,
    I haven't been here for a while! Anyways, does anyone have a good suggestion for the best quad op amp to use for active crossovers? I was looking at the OPA4134 but they discontinued the dip and only have SMT now.
    I guess I could live with that but dips are much easier to breadboard and solder.
    TIA,
    Phil
  2. Paul Stiles
    Paul Stiles Agent
    Oct 4, 2002
    45
  3. Brian Knauss
    Brian Knauss Stunt Coordinator
    Jan 12, 2003
    61
    Go with something Burr Brown since TI has that wonderful "samples" program. I think you'll be able to get 8 of them in a sample order. Just make sure you don't accidently get a micro dip... not fun looking at areas that you need to solder that are about as big as a hair.
  4. Phil Olson
    Jun 30, 1997
    52
    Thanks for the info!
    Phil
  5. Aaron_Smith
    Aaron_Smith Stunt Coordinator
    Jul 22, 2002
    105
    I tried several different dual op-amps in my CD player and headphone amp, and prefer the sound of the national semi LM6172- not sure if they make a quad in a dip. The Burr Browns are pretty nice though. I haven't had any problems using op-amp sockets so I could change them and compare, as long as they are high-quality sockets.
  6. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    Interesting thread. I haven't built any active filters for a few years but I'm thinking about a new subwoofer crossover with an LT. My early crossover projects use National LM833 duals. Later projects used Analog Devices AD797. These were very nice sounding single 8-pin DIPs. I'll have to look into the BurrBrown/TI devices mentioned above... are these 2134/4134 devices significantly better than AD797/AD811?
  7. Paul Stiles
    Paul Stiles Agent
    Oct 4, 2002
    45
    The best sounding op-amps are single devices.
    The AD797 is great but high frequency stability can be difficult to optain.
    Other single op-amp that have a reputation for high quality sound are:
    AD843, AD825 (Analog Devices)
    The AD825 is available only in surface mount packaging.
    and
    OPA627 (Burr-Brown/Texas Instruments)
    Unless there were severe space and cost constraints, I would use single devices.
    Here is a link to more op-amp reviews:
    http://tangentsoft.net/audio/opamps.html
    Paul
