Best compliment for my denon 3802
Discussion in 'AV Receivers' started by DaveU, Jul 22, 2004.
  1. DaveU
    DaveU Auditioning
    Jul 21, 2004
    I was looking for a seperate amp to push my fronts and center speaker. I have IL 80's for left and right fronts and IL 36 for my center. IL 10's for rears. I listen to just about everything from David Coz to Metalica. I also enjoy sci-fi movies. From my equipment you can tell I'm not on a huge budget. Thanks for any suggestions. DaveU
  2. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    I would look for a used Rotel 985. They go for around $500 on ebay. It's a 5ch amp, but you're not going to find alot of 3ch amps out there. It's rated at 100w per ch and THX certified (pretty meaningless but still). You could use the 2 channels not used up front for your surrounds, a second zone, or just let them sit (lets the power supply deliver more current to the other three channels anyway).
    Hope this helps [​IMG]
