Best Cloth For Cleaning Screen?
Discussion in 'Archived Threads 2001-2004' started by Steve_Cohen, Nov 10, 2002.
  1. Steve_Cohen
    Steve_Cohen Stunt Coordinator
    Oct 29, 2002
    52
    I have the Panisonic 53wx52 with the protective screen. What is the best cloth for cleaning the screen? How about cleaning solution?
    thanks
  2. Lando P
    Lando P Agent
    Apr 15, 2002
    40
    Best cloth would be an old soft cotton t-shirt preferably one that's been washed several times. Solution would be lukewarm water - distilled water don't leave haze - with a drop of mild dishwashing liquid.
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    No!
    A much softer cloth is required. Go to your nearest eye specialist now. I only use lense-grade cloths to clean those sorts of surfaces.
  4. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
  5. Richard Travale
    Richard Travale Producer
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
    Are you guys using these methods to clean the screen when there is just dust or when there is actual stuff on the screen?
  6. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Both. Ultimately, though, you can't go wrong with soap and distilled water. And a very, very soft cloth.
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    well worn (and washed) cloth baby diaper. best game in town.
    also, i'm not so sure about that 3m product? doesn't that stuff usually contain high amounts of alcohol to prevent the streaking? i'd be worried that stuff would mess up the screen...
  8. Gabriel_Lam
    Mar 7, 2002
    1,402
    I've used the 3M screen wipes for over 2 years now. Seems pretty good, haven't noticed any problems.
  9. Brent_H
    Brent_H Second Unit
    Aug 14, 2002
    366
    are those screen wipes okay to use if you DO NOT have a protective screen? I have a couple fingerprints in the corner for some reason and I want them gone!
  10. David Von Pein
    David Von Pein Producer
    Feb 4, 2002
    5,748
    10
  11. John Stone
    John Stone Supporting Actor
    Aug 5, 2001
    680
  12. David Von Pein
    Feb 4, 2002
    5,748
    10
    Toshiba makes this claim. Is it true? (I've seen on the Forums that the shield produces MORE glare, not less.) ........
    "TheaterShield™ AR
    This protective shield features a scratch resistant coating, as well as an anti-reflective layer that reduces reflectivity by over 50 percent, thereby reducing glare.
    Benefit: Screen protection, improved contrast and fewer distracting reflections."
  13. David Von Pein
    Feb 4, 2002
    5,748
    10
    Question: Can a "Swiffer" cloth be used on these protective screens without doing any damage?
