Best center to compliment system
Discussion in 'Speakers' started by Brad E, Jan 13, 2004.
  1. Brad E
    Brad E Second Unit
    Jan 11, 2004
    304
    Hello, I just bought 4 JBL ND310 II floor standing speakers.
    My receiver is an H/K 7200.
    Just wondering what the best center speaker would be to compliment the system. I'm definitely going with a JBL but should I go with 2-way or 3-way center?
    I was looking at an N-centerII, which is a 2-way. The price is good $99.00, but my gut is telling me to get a 3-way. I don't know what the difference in sound would be and I'm not able to test them back to back, so any info will help a lot.
    This system will mainly be for TV.
    Brad
  2. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    The center is an important channel in movies, maybe not as much with TV as it isn't usually DD, but none the less I'd get the hopefully better sounding(clear natural sounding voices) more expensive one.
  3. cabreau
    cabreau Second Unit
    Dec 1, 2003
    322
    Without being able to listen to both, I'd probably go with the 3-way.
