Best Center Speaker Suggestions for under $1,000
Discussion in 'Speakers & Subwoofers' started by MarshallSlate, Aug 23, 2003.
  1. MarshallSlate
    Aug 17, 2003
    30
    i got two Athena AS-C1's front and rear, and i heard they are alittle weak and i havent owned any other center speakers for comparison so...i want suggestions on really good center speakers for $1,000 or under.
  2. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    You can look in this area for threads on timbre matching. Assuming that you understand the issues, the best under $1,000 center speaker I have heard is the Rocket RSC200. This costs $600 and it is excellent. I have this as a part of my HT—you can distinguish softly-spoken dialogue in the midst of chaos (of course you have to take the fact that own this as a bit of partiality on my part).
    But, if you are going to consider a center different than your mains, you should check this out.
  3. MarshallSlate
    Aug 17, 2003
    30
    Lew whats your HT consist of?
  4. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    I think Klipsch center channels are some of the best, very strong on the vocals which is basically what you would want for a center.
  5. James~P
    James~P Stunt Coordinator
    Aug 8, 2003
    226
    the horns in Klipsch will give them some nice qualites for dialoug.
    optimally, you need a fully timbre matched front array.
    for 1000 dollars or a little over, you could prolly get some decent bookshelves and a matching center, which would yeild much better results IMHO
  6. Russell _T
    Russell _T Supporting Actor
    Aug 26, 2001
    579
    You do need to consider timbre matching, but if you are just looking for the best center under $1000.00, what Lew said. Rocket "Bigfoot" RSC200 here.
  7. Lew Crippen
    May 19, 2002
    12,060
