Best case cutting method?
Discussion in 'Archived Threads 2001-2004' started by Jeff Braddock, Jul 10, 2002.
  1. Jeff Braddock
    Jeff Braddock Second Unit
    Jan 26, 2002
    306
    What would be the best/easiest case cutting method? Dremel or jigsaw or something else? If it matters, it is one of the old cases...the kind where all of it comes off, not just one panel. Thanks.
  2. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
  3. Jeff Braddock
    Jan 26, 2002
    306
    NickSo,
    I have been following your progress. I like the idea about the screen, very original. I don't think I will be able to do what I orig. wanted. I came up with a plan before I took the case off. I'm a little agravated. Oh well, I guess it's my own fault. I may just cut a square window and save my idea for the next mod.
  4. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Just curious, what were you trying to do? [​IMG]
  5. Jeff Braddock
    Jan 26, 2002
    306
    i'm sure you remember the thundercats cartoon... well, i was going to cut a big tc symbol into the side of the case, paint it all black and put a red light behind it (along with cutting some fan holes). Well, because the way the frame is, if i put a symbol into it, it will only be like 6in. in diameter. Therefore, I just don't know what i'm going to do.
