best bookshelfs under $125?
Discussion in 'Archived Threads 2001-2004' started by david*mt, Dec 19, 2002.
  1. david*mt
    david*mt Second Unit
    Dec 11, 2002
    306
    Can someone give me a recommendation on the best pair of bookshelf speakers I can get for under $125? I am looking for something that I can temporarily use as my fronts, and then later I will move them to my rears when I can upgrade again. I only play movies and never listen to music.
  2. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
  4. Brian Johnson
    Brian Johnson Supporting Actor
    Oct 21, 2001
    739
    Are you only looking for 2 speakers now David?
    I take it you ruled out the quintets eh? I have decided to keep mine and experiment with 'em [​IMG]
    What kind of center did you have again? You may want to see if they have a mathing pair of bookshelves. At least then you will have a good front 3. Then when you upgrade, just buy a matching set of bookshelves for your surrounds.
    Have you went & listened to anything locally yet?
    Speakers are very personal.
    Good luck. Keep us posted on what you decided on.
  5. david*mt
    Dec 11, 2002
    306
    Frank,
    Can you give a link to those speakers? I can't seem to find the JBL N26II's.
  6. Brian Johnson
    Oct 21, 2001
    739
  7. Brian Johnson
    Oct 21, 2001
    739
    I seen these in another thread http://www.fluance.com/fluan5speaks.html and wonder just how good these speakers actually sound. I guess its double your price range though.
    We need a guinnea pig....[​IMG] David?
  8. david*mt
    Dec 11, 2002
    306
    Those aren't the right ones. Here is what Frank was referring to.
    JBL N26II
  9. Brian Johnson
    Oct 21, 2001
    739
    Thats what I thought too.
    But at BH those are fetching a hefty $249.. I went off his price of $130 & assumed the other model.
  10. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
  11. Frank Carter
    Mar 12, 2002
    1,187
    Here is the link to what I was talking about:
    http://www.bhphotovideo.com/bh5.sph/...= F2745412080
    I know it says $249, but underneath the price it says "email me a better price". Just click on it and enter your email address and then it will provide a link back to the site where it's $130 shipped for the pair.
    EDIT: I just realized the price is $139/pr shipped not $130.
  12. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
  13. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Take a little trip to www.ubid.com and do a search on "Wharfedale". They have lots of nice speakers for cheap there.
  14. Jim A. Banville
    Jim A. Banville Supporting Actor
    Jun 20, 1999
    630
    I just ordered 2 pair of Athena (made by API, the company that makes Mirage and Energy speakers) S.5 bookshelf speakers for $150/each pair/shipped. MSRP is $175, and most places charge shipping. You have to call www.onecall.com and speak to someone to get "the deal". These speakers have garnered rave reviews and won an award from Sound & Vision magazine recently.
    Good luck [​IMG]
  15. Ted Kim
    Ted Kim Stunt Coordinator
    Apr 11, 2002
    214
    My budget choices are as follows:
    Phase Technology Teatro 4.5 available for $163 at ubid -- see their superstore. Got a great review in HT mag, and the reviewer ended up buying them, as part of a system, if I recall correctly. He had the Phase Tech speakers matched with Krell gear, believe it or not, so their price/performance ratio should be quite high.
    Mission MS731 at ubid for $112-- see their superstore. The original 731i got a great review in Stereophile and a friend bought them. I've listened to them and thought they were a great speaker at a very cheap price. Their only drawback was the treble was a little shelved down and the bass only goes so low, but what a midrange. The MS731 should be a bargain as well. At a little higher price, the MS 771 is about $176. Probably a good step up.
    Aura LSB-527. A personal budget fave, especially at $55 a pair on ebay. They list for something around $280 new, but the company went under. A great cheap speaker, but at 6 ohms, need some current to drive them. That ribbon tweeter is quite natural sounding and the midrange is quite good as well, comparing well to some speakers that cost around $1000. I use them in my office system and find they are quite good, especially for the $$$. A good match for Sherwood Newcastle amps. See the review on audiorevolution.com
    Any of these speakers would make great choices, but you would have to match them with the right amplification to get the most out of them.
