Best 2-channel amp $300 or under
Discussion in 'Archived Threads 2001-2004' started by James_T, Nov 11, 2001.
  1. James_T
    James_T Stunt Coordinator
    Jul 9, 2000
    89
    My parents need an amp to connect to a Marantz SR-7000 and thus provide multi-room capability (the amp is for the second room, where most music is listened to). What is the best one at $300 or under that can be bought ASAP (ie no waiting for a special deal on ebay or audiogon)?
  2. Jeffrey Noel
    Jeffrey Noel Screenwriter
    Sep 11, 2001
    1,533
    I've heard really good things about this 2-channel amp. It's priced at $249.99, but you should be able to talk the price down if you call JandR.com, as I have done on other products before.
    Here it is: http://www.jandr.com/JRProductPage.p...827&showcase=t
    God bless!
    jeffrey noel
    My DVD Collection
    [Edited last by Jeffrey Noel on November 11, 2001 at 02:00 PM]
  3. Steve Daniels
    Steve Daniels Stunt Coordinator
    May 14, 2001
    144
    I'll second the recommendation for the AudioSource amp.
    I'm using the very similar AudioSource Amp One (not 1A) for my multi-room. The volume pots and headphone jack are a definite bonus.
  4. James_T
    Jul 9, 2000
    89
    Thanks, guys. I've heard good things about these amps myself, so I guess they are the best way to go for the price. I'll order one tomorrow for my folks.
  5. Mike_Ped
    Mike_Ped Second Unit
    May 16, 2001
    252
    Look at www.half.com for deals. There is no waiting for an auction to end and it works really well. I bought a Carver M-500t from there for $275 and it was shipped within 2 days, got to me within 5 days. Just a suggestion.
    Mike
  6. Rich G
    Rich G Stunt Coordinator
    Aug 22, 2000
    115
    You may want to consider a receiver. I use a receiver for a second room. By using a receiver you have these benefits:
    - You can listen to the radio without haveing to turn on the main system.
    - You may have an extra set of speaker outputs available. My B speakers go to the patio.
    - You can change stations with out going to the main room.
    - You can change volume if the amp does not have volume control.
    - You will have a sub output for an SVS in the kitchen. he he.
    Rich G.
  7. Steve Daniels
    May 14, 2001
    144
  8. Rich G
    Aug 22, 2000
    115
    Steve, you are correct. I wasn't sure if that amp had volume control or if he settled for sure on that amp. I also agree just an amp, especially one with lit power meters, would look good.
    Rich G.
