Best 1080p projector for my budget? (2-3K) (1 Viewer)
Guy_K
Looking for the best 1080P projector for my budget, probably can't go any higher, so if there are any excellent projectors in that range available yet, I would like to hear about them, thanks for any help!
Guy_K
Thanks, looks like the AE2000 is good for me... are projectors better than HD LCTV screens? I am deciding if I should get the Samsung LNT4665 46" HD LCD or this projector
SethH
You'll have to give more information on the uses and environment. From a "size-for-the-dollar" perspective you really can't beat a projector. If you are in a bright room and/or are going to use this for watching the news, etc for several hours per day then a projector probably don't make much sense.
Guy_K
Thanks for all the tips! Just went for the Panasonic, now I am just trying to figure out viewing distance info.
Zola_88
