Ken Lopata
- Feb 7, 1999
Which one would be the best to use with the dual Stryke HE15 sub I'm having built. I'm using a Crown K2 amp if this makes any difference. Is one easier then the other to use.
I've already bought a Beringer FBD Pro for 159.95. If the Art 31 is a lot better I can return it. With the combination of a dual HE15 and 6 p.r. sub and Crown K2 amp, I should never have to buy another sub. I want to get the best e.q. for the job.
Thanks, Ken
Thanks, Ken
