Steve Morgan
Okay BFD owners I have a B&K Ref 30 with one sub output. I have 2 subs a Servo 15 and a SVS which is being driven by 1 channel of a Parasound 2205a.I know I need a RCA to 1/4" Stereo Jack converter plug.2 right? Do I run the Audio cable from the Amp into the BFD input 1 and then the servo into input 2?Then where does the cable from the Ref 30 go? As you can tell I need help? What are the steps I need to start using the BFD. I have never used an EQ before so I will need your guys expertise. Thanks For your Help!Steve
Wayne YGM!
Wayne YGM!
