Benq Projector
Discussion in 'Displays' started by CarlosGH, Jun 15, 2004.
  1. CarlosGH
    CarlosGH Stunt Coordinator
    Jan 11, 2004
    74
    I recently saw an infomercial on the shopathometv.com channel for a Benq projector with DLP technology. They say that it has composite, s-video, progressive scan component video and SVGA input. The native resolution says it is 800x600, but they say it supports both 720p and 1080i HDTV resolutions. Is this true or BS? At $1500 for the DLP projector and an 84inch screen it seems to good to be true.
  2. CarlosGH
    Jan 11, 2004
    74
  3. Dan Wesnor
    Dan Wesnor Second Unit
    Apr 28, 1999
    389
    There's no reason all those specs can't be true at that price point. However, that still doesn't mean it's too good to be true. $1500 is a lot of money to spend if the stuff ends up being crap with nice specs.
  4. Dan Wesnor
    Apr 28, 1999
    389
  5. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    CarlosGH may I suggest that you do a search on this section of the HTF for "Benq" and see what you come up with.
    You should see my name in a coupla them.
    It's great, but get the Zenith 318 or in Canada get the LG 7832 DVD player and you'll knock yourself off you chair.
    Esp for the money
    Brent
    Projector can be had for under $900, build your own screen for $30 and buy the DVD player for under $200 and go CRAZY!
  6. brentl
    May 7, 1999
    2,921
    110
    Esp for the money
    Brent
  7. CarlosGH
    Jan 11, 2004
    74
    So the projector can produce HDTV resolution even though its native SVGA resolution is only 800x600? Benq is a very good company that makes excellent products, what I've read is that they are big in Europe. I bought a negative scanner from Benq and it ROCKS! So if it can display HDTV, then I guess that it is a good price. Escpecially for a good screen and projector. Its only fault is that it doesn't have DVI. I saw a pic of it, it doesn't have component in, but rather a SVGA->Component adaptor. Does this degrade the quality? Does it still allow for progressive input?
  8. CarlosGH
    Jan 11, 2004
    74
  9. brentl
    May 7, 1999
    2,921
    110
    It offers component through an adapter and you don't lose any quality.
    It can display an HD image, but it lowers the resolution to the maximum the Benq can display.
    I'm running a 1080i progressive signal in and it looks great..
    Go see one in action and you'll buy it!
    "then I guess that it is a good price" UHM were you looking for a cheaper solution?
    B
  10. brentl
    May 7, 1999
    2,921
    110
    B
