BenQ PB6100 Information question (1 Viewer)
jasm
Anyone know?
On the second menu (Image Menu)at the bottom of the screen it says 'information 720x480 60 mhz'(its greyed out)
I'm running component video to a VGA component adapter using a 480p setting on my dvd.
Are these the correct dimensions?
The projector is Native: 800x600 Pixels
brentl
You're inputting a widescreen signal at 60Hz, it's fine.
Change to 4:3 on the DVD player and you'll see 800/600 at 60hz.
B
atlanticshores
