Benq 6100 PIP question
Discussion in 'Displays' started by Bobby_Ray, Jan 14, 2005.
  1. Bobby_Ray
    Bobby_Ray Auditioning
    Dec 20, 2004
    13
    I am running directTV and i have cable 2-99 without a cable box. How can i set this up so i can get Directv as the main picture and cable in the PIP. The cable only has coax so i need to convert the coax into a usable input plug, right?
  2. John Brill
    John Brill Supporting Actor
    Nov 3, 2003
    519
    Right.
    The way I achieve this is having the coax cable go into my VCR and use the S-Video out from the VCR to the projector. All other sources (X-Box, DVD, and Digital Cable) feed into my receiver and I run component cable from there to the projector.
    Hope this helps.
    JB
  3. Bobby_Ray
    Dec 20, 2004
    13
    Yeah, that will work with me just have to use a vcr, thanks for sharing the idea.
