Benefits of On Screen Display?
Discussion in 'AV Receivers' started by Tamer C, Jun 4, 2003.
  1. Tamer C
    Tamer C Agent
    Apr 25, 2003
    34
    Hi,
    I am trying to decide between a Yamaha RX-V740 and RX-V640. One of the differences is the OSD. I will have to run a separate composite/svideo cable from receiver to tv for this. I'm not passing video through my receiver. What are the main benefits of having the OSD?
    Thanks!
  2. Guy Usher
    Guy Usher Supporting Actor
    Oct 20, 2002
    780
    It is a hell of a lot easier to set up. . .
  3. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Typically the onscreen display has more characters and can be more informative than the display on the receiver.
    Also makes it much easier to calibrate from your normal listening position as you don't have to squint at a tiny receiver display from across the room.
  4. Tamer C
    Tamer C Agent
    Apr 25, 2003
    34
    Thanks for the responses. I will try to make a decision.
  5. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    I do hereby humbly disagree. I have set up my last 3 pre/pros *without* an OSD. I absolutely refuse to string an extra cable only for this. [​IMG] Sony TA-E9000ES, Outlaw 950, Lexicon MC-8. Used only the display on the unit.
