Below $200 dvd player (1 Viewer)
Ricky Hartanto
Hi,
I would like to purchase a a dvd player with progressive scan and VCD playback below $200. A multiregion capability would be preferable although not essential.
However, I do not know if the TV should support progessive scan capability for it to be fully functional. I am getting a 27 inches TV with flat tube. Hence if the progressive scan dvd player will not give any improvements, then I would not need the progressive scan capability.
Would you please help me getting a new dvd player and where to buy it? I am a newbie and getting my first HT setup.
Thank you so much for your help.
nb: pardon my language as English is a second language for me.
Dave Dahl
Welcome to the brave, new world that is Home Theater
The progressive feature found in some DVD players may only be used with a digital television (either EDTV or HDTV). If you are using a standard analog set and don't plan on getting a new tv in the next year or so then don't worry about the progressive feature.
-Dave
MusicLover95
